Connectivity.Explorer.ExtensibilityTools.ExplorerLoader Problem
I have developed an Inventor addin which is compiled as a dll and run as an addin.  I would like to be able to perform some vault commands as well as download and add vault parts into assemblies which designers are currently working on.  I am able to make a connection to Vault, perform searches and querries, but the problem I'm having is when I'm attempting to set an IExplorerUtil object.  The error occurs on this line:
Dim VaultExpl As IExplorerUtil = _
        ExplorerLoader.LoadExplorerUtil(Server, VaultName, UserID, Ticket)
 And the specific error details I'm receiving are:
"Unable to cast object of type 'Connectivity.Explorer.ExtensibilityUtil.ExplorerUtil' to type 'Autodesk.Connectivity.Explorer.ExtensibilityTools.IExplorerUtil'."
System.InvalidCastException was unhandled
  Message=Unable to cast object of type 'Connectivity.Explorer.ExtensibilityUtil.ExplorerUtil' to type 'Autodesk.Connectivity.Explorer.ExtensibilityTools.IExplorerUtil'.
  Source=Autodesk.Connectivity.Explorer.ExtensibilityTools
  StackTrace:
       at Autodesk.Connectivity.Explorer.ExtensibilityTools.ExplorerLoader.LoadExplorerUtil(Product product, String server, String vaultName, Int64 userId, String ticket, String loadPath, String overrideLoadPath)
       at Autodesk.Connectivity.Explorer.ExtensibilityTools.ExplorerLoader.LoadExplorerUtil(String server, String vaultName, Int64 userId, String ticket)...
Any help would be greatly appreciated.
Marat.Mirgaleev
Could you add information about the server and client versions, please?
Marat Mirgaleev
Developer Technical Services
Autodesk Developer Network
We are using Vault Callaboration 2013
Marat.Mirgaleev
1) Could you, please, make sure that the latest updates for Vault are installed.
2) Do you use the "Option Strict On" statement in your VB code? I hope it may find the problem at the compile time, not at the run time.
Marat Mirgaleev
