Commandsite & Search Conditions (Where to place in Handler?)
Hi
I followed the HelloWorldVB example to create a custom extension within Vault explorer. My question is, is it possible in the handler for there to be a filter or to apply search conditions to where items in the detail pane are filtered out based on the handler or commandsite? I have done many search conditions before. I'm just not sure where you put the search condition inside the handler or the commandsite. The only difference between the handler below and the one in the SDK is I changed it to work on a folder instead. But I'd like to add a filter. If you have any experience with this I'd appreciate some direction.
Thank you!
Tiffany
Private Sub Vault_WhereUsedHandler(s As Object, e As CommandItemEventArgs) As ACW.Folder
Try
' The Context part of the event args tells us information about what is selected.
' Run some checks to make sure that the selection is valid.
If e.Context.CurrentSelectionSet.Count() = 0 Then
MessageBox.Show("Nothing is selected")
ElseIf e.Context.CurrentSelectionSet.Count() > 1 Then
MessageBox.Show("This function does not support multiple selections")
Else
' we only have one item selected, which is the expected behavior
Dim selection As ISelection = e.Context.CurrentSelectionSet.First()
Dim mgr As WebServiceManager = e.Context.Application.Connection.WebServiceManager
' Look of the File object. How we do this depends on what is selected.
Dim selectedFile As ACW.File = Nothing
Dim selectedFolder As ACW.Folder = Nothing
'If selection.TypeId = SelectionTypeId.File Then
' ' our ISelection.Id is really a File.MasterId
' selectedFile = mgr.DocumentService.GetLatestFileByMasterId(selection.Id)
'ElseIf selection.TypeId = SelectionTypeId.FileVersion Then
' ' our ISelection.Id is really a File.Id
' selectedFile = mgr.DocumentService.GetFileById(selection.Id)
'End If
If selection.TypeId = SelectionTypeId.Folder Then
selectedFolder = mgr.DocumentService.GetFolderById(selection.Id)
'If selectedFile Is Nothing Then
' MessageBox.Show("Selection is not a file.")
'Else
' ' this is the message we hope to see
' MessageBox.Show([String].Format("Hello World! The file size is: {0} bytes", selectedFile.FileSize))
'End If
If selectedFolder Is Nothing Then
MessageBox.Show("Selection is not a Folder.")
Else
MessageBox.Show([String].Format("Hello World! The file size is: {0} bytes", selectedFolder.FullName))
Catch ex As Exception
' If something goes wrong, we don't want the exception to bubble up to Vault Explorer.
MessageBox.Show("Error: " & ex.Message)
End Try
End SubCommandsites
Public Function CommandSites() As IEnumerable(Of CommandSite) Implements IExplorerExtension.CommandSites
' Create the Hello World command object.
' this command is active when a File is selected
' this command is not active if there are multiple entities selected
Dim AVMCmdItem As New CommandItem("AdvancedVaultMenu", "Filter Where Used") With {
.NavigationTypes = New SelectionTypeId() {SelectionTypeId.Folder, SelectionTypeId.FileVersion},
.MultiSelectEnabled = False
' The HelloWorldCommandHandler function is called when the custom command is executed.
AddHandler AVMCmdItem.Execute, AddressOf Vault_WhereUsedHandler
' Create a command site to hook the command to the Advanced toolbar
Dim toolbarCmdSite As New CommandSite("AdvancedVaultMenu.Toolbar", "Advanced Vault Menu") With {
.Location = CommandSiteLocation.AdvancedToolbar,
.DeployAsPulldownMenu = True
toolbarCmdSite.AddCommand(AVMCmdItem)
' Create another command site to hook the command to the right-click menu for Files.
Dim FolderContextCmdSite As New CommandSite("AdvancedVaultMenu.FolderContextMenu", "Advanced Vault Menu") With {
.Location = CommandSiteLocation.FolderContextMenu,
FolderContextCmdSite.AddCommand(AVMCmdItem)
' Now the custom command is available in 2 places.
' Gather the sites in a List.
Dim sites As New List(Of CommandSite)()
sites.Add(toolbarCmdSite)
sites.Add(FolderContextCmdSite)
' Return the list of CommandSites.
Return sites
End Function
Tiffany Hayden
