Changing or adding comments to Versions of file
mateusz_baczewski
mateusz_baczewski
I would like to change or add a comment to the historical versions of files in Vault. Is it possible to modify this comment via the API?
If you found it helpful, a "Like" would be much appreciated!
If this post solved your problem, please mark it as "Solution.".
Markus.Koechl
You cannot change a comment in historical file iterations. Updating comments (through the API or UI) is done either by checking in a new file iteration or by making an explicit property edit. In any case, the result is a new file version. Changing historic iterations would jeopardize the traceability of changes and, therefore, vaulting principles.
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
mateusz_baczewski
I suspected as much; thanks for the information.
