Automate monotone task, convert tif to dwg
Ystrm_Bek
Ystrm_Bek
Hello
Hopefully this is the right forum to ask this.
We currently have a vault with alot of old .tif files that we want to convert to dwg files.
The way we do this is following these steps:
-Get .tif file
-Create new Autocad file
-Insert .Tif file in Autocad through Raster design
-Image embed (delete link with .tif file)
-Save new file as dwg
-Replace file in Vault.
Is there any way that one could automate a task like this? I'm very new to programming and have never created an add-in or something like that. I've just done some basic ilogic programming in Inventor. I don't know if I'm grasping for too much, but it seems like ther should be a better way to do this. It's a fairly easy task, but a big time consumer for our company.
Markus.Koechl
Hello, this task sounds like a perfect fit for Vault Job Processing. And it might be the quickest solution to reach out to an Autodesk Vault reseller or CoolOrange (powerJobs).  They have existing job frameworks that allow configuring your task instead of programming it from scratch. However, the actions within AutoCAD might need some additional scripting.
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
Nick_Hall
Hello
You don't say whether this is a one-off task, or whether it's something that will happen continuously
If it is the second option, I would agree with @Markus.Koechl and use Vault Job Processor
If it is the first, I'd use something simple - AutoCAD scripts
A simple script that does what you want is
FILEDIA
0
IINSERT
C:\Temp\bitonal_file_example_TIFF_1MB.tiff
NO
ZOOM
EXTENTS
IEMBED
SAVE
C:\Temp\bitonal_file_example_TIFF_1MB.dwg
You can start AutoCAD and make it run a script file using the command line
See https://help.autodesk.com/view/ACD/2023/ENU/index.html?guid=GUID-7FDC500C-E04A-432D-A73D-EB1B6C6728B...
The full set of command line switches is here - https://help.autodesk.com/view/ACD/2023/ENU/index.html?guid=GUID-8E54B6EC-5B52-4F62-B7FC-0D4E1EDF093...
So the process you could use is
  1. Download the TIFF files from Vault
  2. Generate a script for each drawing, and a batch file to run the scripts
  3. Run the batch file
  4. Use the AutoCAD Vault add-in to check in all the DWGs
Also, with a bit of thought/work, it would be possible to create a single batch file that combines steps 2 & 3
If you are interested in this approach, let me know. I might be able to point you in the correct direction
Nick
Ystrm_Bek
Hello and thanks for the reply.
It's the second option. We have a Vault with a very large number of raster drawings, scattered over hundreds of folders. Every now and then we have to work with these files, and it'd be great if one could convert it to a dwg with a click of a button.
The first option you explained, with autocad macro is certainly doable, but it does not save that much time as I'd hoped. My goal is to not have to do the "download - change - replace" action, since we're not working with the drawings in bulk, it's mostly one at a time.
I'll look closer into the Vault Job processor, and see what it can do.
Thank you
Nick_Hall
Hi again
Using Job Processor, the job would have to be run against the TIFF file
The simplest flow of the job would be
  1. Download the TIFF file to a temporary folder
  2. Write a script file as above to the temporary folder
  3. Copy a template drawing to the temporary folder, with a suitable name
  4. Run the script using AutoCAD, on the new DWG, which will import the TIFF file and save it
  5. Add the DWG to Vault, in the same folder as the TIFF file
  6. Tidy up the temporary folder
You can do all of this as a custom job, but it has to be written in C# or VB.NET.
Another option, if you are not confident with building add-ins, is to use an add-in for Job Processor, called powerJobs by coolOrange - https://www.coolorange.com/powerjobs which allows you to create custom jobs as scripts, using PowerShell - https://learn.microsoft.com/en-us/powershell/
Personally, I would use powerJobs because the speed of development is faster, but both methods will work
One other thing, regardless of which method you use to write your custom job, the machine that you run the Job Processor on will need a license of AutoCAD as well as the Vault Pro license, so you will either need to run it on one of your CAD workstations, or buy new VP + AutoCAD licenses if you want to implement a dedicated Job Processor
Finally, you'll need a way of submitting the job to the queue, which could be via a Lifecycle State change, or a tool such as qJob https://apps.autodesk.com/VLTC/en/Detail/Index?id=5159126042722483562&appLang=en&os=Win32_64
Hope that's all useful
Nick
