Assembly structure not visible in Vault Client 2023 after rename
bshinde3ZRN3
New Member New Member
bshinde3ZRN3
New Member
New Member
Hello Sir,
I’m currently working on a customization project involving Autodesk Inventor and Vault. As part of the workflow, I checked in an assembly named assembly1.iam into Vault. This assembly includes two child components: part1.ipt and part2.ipt. After the initial check-in, the Vault Client correctly displayed both child parts under the Uses tab.
Following this, I executed a custom action via a button that programmatically performs the following steps:
  1. Checks out the assembly.
  2. Renames the child parts first, followed by the assembly.
  3. Updates the references accordingly.
  4. Checks the renamed assembly back into Vault.
After this process, the renamed assembly opens correctly in Inventor along with its renamed child components, indicating that the references are intact. However, in the Vault Client, the Uses tab no longer displays the child associations for the renamed assembly.
Could you please advise why these associations are not visible in Vault Client and how this issue can be resolved?
Thank you,
Richard.Rankin
Autodesk Support
Autodesk Support
Hi @bshinde3ZRN3
Can you reproduce this behaviour when you manually follow those steps? (Using the User Interface).
If you cannot reproduce the issue manually, it may be a problem with your code that would be best addressed by posting this question in the Vault Customisation forum.
If you find my response solves your question, please click the "Accept Solution" below the response
Richard Rankin
Vault Support Specialist
Global Product Support
Autodesk, Inc.
bshinde3ZRN3
New Member
New Member
Hi Richard,
I performed same steps using UI and i am able to see the structure in Vault Client without any issues. I am expecting similar behavior when I am doing it programmatically. But it is not working. Similar behavior is happening with a simple part and its associated drawing.
Bhushan
ihayesjr
@bshinde3ZRN3
Why are you building something custom to rename the children?
Where are the new names coming from?
Irvin Hayes Jr
Principal Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
bshinde3ZRN3
New Member
New Member
We are currently working on integrating Vault with 3DX. As part of this process, it's important to note that 3DX enforces strict naming conventions within Enovia—parts must adhere to specific naming rules provided by 3DX. The customer has requested that all legacy data be renamed to align with these conventions. To support this, we are renaming the assemblies using the new names supplied by 3DX.
I am using below function RenameFileViaUpload to rename the parts first, then i am using another function RebuildAssemblyFromVaultStructure to update the references in assembly, then i am calling RenameFileViaUpload to rename assembly. Here are the functions:
public static void RenameFileViaUpload(
VDF.Vault.Currency.Connections.Connection connection,
Autodesk.Connectivity.WebServices.File file,
string newName)
try
var wsFolder = connection.WebServiceManager.DocumentService.GetFolderById(file.FolderId);
var vdfFolder = new VDF.Vault.Currency.Entities.Folder(connection, wsFolder);
// Step 2: Get the local working folder path
string localFolderPath = connection.WorkingFoldersManager.GetWorkingFolder(wsFolder.FullName).FullPath;
string originalFilePath = Path.Combine(localFolderPath, file.Name);
string newFilePath = Path.Combine(localFolderPath, newName);
//Checkout the file
MxLogger.LogEnovia("Checkout the file.");
VDF.Vault.Settings.AcquireFilesSettings aqSettings = new VDF.Vault.Settings.AcquireFilesSettings(connection)
DefaultAcquisitionOption = VDF.Vault.Settings.AcquireFilesSettings.AcquisitionOption.Checkout
FileIteration vdfFile = new FileIteration(connection, file);
aqSettings.AddEntityToAcquire(vdfFile);
AcquireFilesResults results = connection.FileManager.AcquireFiles(aqSettings);
FileAcquisitionResult fileAcquisitionResult = results.FileResults.FirstOrDefault();
// Step 3: Download the file to the local folder
MxLogger.LogEnovia("Download the file to the local folder.");
var acquireSettings = new VDF.Vault.Settings.AcquireFilesSettings(connection)
LocalPath = new VDF.Currency.FolderPathAbsolute(localFolderPath)
acquireSettings.AddEntityToAcquire(new VDF.Vault.Currency.Entities.FileIteration(connection, file));
connection.FileManager.AcquireFiles(acquireSettings);
// Step 4: Rename the file locally
MxLogger.LogEnovia("Rename the file locally.");
if (System.IO.File.Exists(newFilePath))
System.IO.File.Delete(newFilePath); // Avoid conflict
System.IO.File.Move(originalFilePath, newFilePath);
// Step 6: Upload the renamed file using FileManager.AddFile
MxLogger.LogEnovia("Upload the renamed file.");
using (var stream = new FileStream(newFilePath, FileMode.Open, FileAccess.Read))
var renamedFile = connection.FileManager.CheckinFile(
new FileIteration(connection, file),
"renaming to new name",
false,
DateTime.Now,
null,
null,
false,
newName,
Autodesk.Connectivity.WebServices.FileClassification.DesignDocument,
false,
stream
catch (Exception ex)
MessageBox.Show($" Rename via upload failed for '{file.Name}': {ex.Message}", "Rename Error");
public static bool RebuildAssemblyFromVaultStructure(
VaultFile renamedParentFile,
Dictionary<string, string> renameMap,
out string message)
message = string.Empty;
if (connection == null) { message = " Null Vault connection."; return false; }
if (renamedParentFile == null) { message = " Null parent file."; return false; }
if (renameMap == null || renameMap.Count == 0) { message = " Empty rename map."; return false; }
Application invApp = null;
bool createdNewInstance = false;
try
// ---- Resolve latest WS File for the parent (the rename changed Name but ID stayed) ----
var ws = connection.WebServiceManager;
var parentLatest = ws.DocumentService.GetFileById(renamedParentFile.Id);
if (parentLatest == null)
message = $" Could not resolve parent by Id: {renamedParentFile.Id}";
return false;
// ---- Acquire locally: CHECKOUT parent (we will Save), DOWNLOAD children ----
// Parent checkout
var parentIter = new FileIteration(connection, parentLatest);
var acqParent = new AcquireFilesSettings(connection)
DefaultAcquisitionOption = AcquireFilesSettings.AcquisitionOption.Checkout
acqParent.AddFileToAcquire(parentIter, AcquireFilesSettings.AcquisitionOption.Checkout);
connection.FileManager.AcquireFiles(acqParent);
// Gather children (latest) to compute their local paths and ensure they’re present
var childLatest = GetLatestChildFiles(connection, parentLatest);
if (childLatest.Count > 0)
var acqChildren = new AcquireFilesSettings(connection)
foreach (var f in childLatest.Values)
acqChildren.AddFileToAcquire(new FileIteration(connection, f),
connection.FileManager.AcquireFiles(acqChildren);
// Resolve parent local path using StatusResolution
var parentLocalPath = connection.WorkingFoldersManager.GetPathOfFileInWorkingFolder(parentIter).ToString();
if (string.IsNullOrWhiteSpace(parentLocalPath) || !System.IO.File.Exists(parentLocalPath))
message = $" Local assembly path not found after acquire: {parentLocalPath}";
return false;
// Build NEW name -> local path lookup for renamed children
var newNameToLocalPath = BuildNewLocalPathLookup(connection, childLatest);
// ---- Attach or start Inventor headless ----
invApp = AttachOrStartInventor(out createdNewInstance);
invApp.SilentOperation = true;
// ---- Open assembly and replace references via descriptors ----
var asmDoc = (AssemblyDocument)invApp.Documents.Open(parentLocalPath, false);
int replaced = 0;
foreach (DocumentDescriptor dd in asmDoc.ReferencedDocumentDescriptors)
var oldLeaf = System.IO.Path.GetFileName(dd.FullDocumentName);
if (oldLeaf == null) continue;
if (renameMap.TryGetValue(oldLeaf, out var newLeaf))
if (newNameToLocalPath.TryGetValue(newLeaf, out var newFull) && System.IO.File.Exists(newFull))
dd.ReferencedFileDescriptor.ReplaceReference(newFull);// preserves constraints/placement
replaced++;
// Update & Save
asmDoc.Update();
if (!System.IO.File.GetAttributes(parentLocalPath).HasFlag(FileAttributes.ReadOnly))
asmDoc.Save();
else
message += "\n File is read-only. Cannot save.";
return false;
asmDoc.Close(true);
// ---- Check-in parent WITHOUT explicit associations (let server extract refs) ----
parentIter,
"Updated assembly after rename",
false, // keepCheckedOut
DateTime.Now,
null, // file associations
null, // file link settings
false, // allow library update
null, // file classification
false, // is content source
null // content source info
message = $" Assembly updated and checked in.\nReplaced references: {replaced}\n{parentLocalPath}";
return true;
message = $" Error rebuilding assembly: {ex.Message}";
return false;
finally
if (createdNewInstance && invApp != null)
try { invApp.Quit(); } catch { /* ignore */ }
Marshal.ReleaseComObject(invApp);
invApp = null;
GC.Collect(); GC.WaitForPendingFinalizers();
