ASP.NET Core 5.0/C#/MVC Web app error: The requested security protocol is not supported.
We would like to have Vault logic built into our business logic through an internal Web app. Testing a connection to our vault server, we get the error "The requested security protocol is not supported."
Error:
System.TypeInitializationException: 'The type initializer for 'Autodesk.DataManagement.Client.Framework.Vault.Library' threw an exception.'
Inner Exception
NotSupportedException: The requested security protocol is not supported.
Code:
public static Connection VaultConnection()
VDF.Vault.Results.LogInResult results = VDF.Vault.Library.ConnectionManager.LogIn("Server", "Name", "Administrator", "", AuthenticationFlags.Standard, null);
Connection connection = results.Connection;
return connection;
public static bool VaultConnectionStatus()
return VaultConnection().IsConnected;
public string Index()
return $"Vault Connection: {VaultConnectionStatus()}";
Using statements:
using Autodesk.DataManagement.Client.Framework.Vault.Currency.Connections;
using Autodesk.Connectivity.WebServices;
using Autodesk.Connectivity.WebServicesTools;
using VDF = Autodesk.DataManagement.Client.Framework;
References (x64):
Autodesk.DataManagement.Client.Framework.Vault.dll
Autodesk.DataManagement.Client.Framework.dll
Autodesk.Connectivity.WebServices.WCF.dll
Autodesk.Connectivity.WebServices.dll
Autodesk.Connectivity.Extensibility.Framework.dll
Environment:
IDE: Visual Studio 2019 | .Net core 5.0 | using IIS Express to test
Vault Server: Vault Basic Server 2021.1.1 Build 26.1.152.0
olegd.prod
Are you connecting to the Vault server using HTTPS?
If so, how is that configured on the server? Does it require a specific protocol?
.NET FW code below is based on a guess. Try to put it into your app's startup procedure. I haven't tested it with .NET Core
var vals = Enum.GetValues(typeof(SecurityProtocolType)).Cast();
SecurityProtocolType res = SecurityProtocolType.SystemDefault;
foreach (var item in vals)
res = res | item;
ServicePointManager.SecurityProtocol = res;
It is not connecting via https.
//Ssl3 | Tls | Tls11 | Tls12 | Tls13
var vals = Enum.GetValues(typeof(SecurityProtocolType)).Cast<SecurityProtocolType>();
    res |= item;
I added the code above, and I receive the exact same error. I actually commented out the vault connection code and just tried to set the SecurityProtocol via your code, and I received the exact same error.
It seems to be related to being a .Net Core 5.0 project. I created a new project at .Net Framework 4.7.2 and set the Platform Target to x64 and Bitness to x64 and I was able to connect to our vault server without issue.
I'd still like to get the .Net Core 5.0 project working. Is there a different way to handle the SecurityProtocol in .Net Core 5.0? Do the vault DLL's work inside the .Net Core 5.0 environment?
olegd.prod
We haven't tested the SDK with .NET Core, only with the FW, so not sure exactly what's going on.
Sounds like you have a way to move forward
I do not believe that .NET Core is currently supported. I have seen several threads asking whether it was, and I believe the majority of the answers are no or not yet.
