Welcome to the Upchain Ideas Board! Before posting, please read the helpful tips here. Thank you for your Ideas!
Solidworks plugin UI design request - change the order of attributes.
In the Upchain Solidworks plugin, when viewing Common attributes, the current order of the attributes is Shape, Material, Mass and then Finish. Since ATS does not make use of Mass attribute that much we would prefer if this attribute is moved to the bottom of the list. I attached a screenshot.
1 Comment
imckenzieY7CGY
The field does not appear to be dynamically linked to anything and has no units (ie., the field is useless). It is unclear why this mass field was added, but it should be moved out of the way of the fields we use. If it must be there, it should appear after heat treat. But if it's not dynamically linked to the calculated mass of a part or assembly, it's going to be wrong more often than not and should just be removed entirely to avoid errors.
