Welcome to the Upchain Ideas Board! Before posting, please read the helpful tips here. Thank you for your Ideas!
Excel addin should allow for the Creation of items and BOMs using existing Item
the Excel addin has a very limited Usability currently. allowing the user only to create items and BOMs with items in Development status.
the following would create a great benefit for the users.
  • The Excel addin should identify existing Items in Upchain if the users adds the item number in the correct mapped column. “this is already the case
  • The Excel addin should should distinguish between existing Items, “ where the user adds an item number in the column” and non-existing/new items. “ where the user added Item-Name., item-type etc.”
    • only new items should be created by the part.
  • Existing item properties should adhere to the item Status.
    • Released Items will not be changed but only the BOM Position, Structure Quantity and BOM relevant properties should be modified and added.
    • Items in Development could be changed if the value differs from the DB.
  • Non-Existing Parts should be created and added to the BOM, as the function does now.
this functionality would enable users to create BOM structures by pulling data from Upchain.
2 Comments
Thank you for submitting this idea!
This idea has been moved into future consideration and we have all the required info. We will keep you informed if the status changes.
Best regards,
Andreja Schneider
mwaxenberger
All atrributs should be supported by the tool such es Shape, Finish, and heattreat.
