Issue:
Upon project delivery, our customers require documentation contain some PDF and STEP files. Upchain does not support a solution, other than a very manual heavy operation of extraction all the information from Upchain, hence high risk of errors.
The general feature we are looking for is an additional option to limit the bulk export to selected filed.
3 options could solve the issue:
a) eBOM attributes:
In the Bulk export eBOM export options, an addition line with check boxes of the available e-BOM attributes. Only files that have a "OK" value in the selected e-BOM attribute are exported.
b) cBOM attribute “Customer documentation”:
In the CAD plug in next to recommended "recommended spare part" there is added a check box named "costumer documentation"
During eBOM or cBOM Bulk export it is possible to select "spare part" or "costumer documentation" and only the files from the item that meet the selected requirement.
c) Advanced search:
In the Bulk export eBOM export options there is an “advanced search” possibility to filter items in the bulk export for the selected item.
the item types that is required.
