Welcome to the Upchain Ideas Board! Before posting, please read the helpful tips here. Thank you for your Ideas!
Bulk export of customer documentation
Issue:
Upon project delivery, our customers require documentation contain some PDF and STEP files. Upchain does not support a solution, other than a very manual heavy operation of extraction all the information from Upchain, hence high risk of errors.
The general feature we are looking for is an additional option to limit the bulk export to selected filed.
3 options could solve the issue:
a) eBOM attributes:
In the Bulk export eBOM export options, an addition line with check boxes of the available e-BOM attributes. Only files that have a "OK" value in the selected e-BOM attribute are exported.
b) cBOM attribute “Customer documentation”:
In the CAD plug in next to recommended "recommended spare part" there is added a check box named "costumer documentation"
During eBOM or cBOM Bulk export it is possible to select "spare part" or "costumer documentation" and only the files from the item that meet the selected requirement.
c) Advanced search:
In the Bulk export eBOM export options there is an “advanced search” possibility to filter items in the bulk export for the selected item.
the item types that is required.
6 Comments
PualQuek
Hi @lho1 ,
To ensure I fully understand your request, it seems you're looking for a method to swiftly gather relevant documentation from specific eBOM/cBOM items, while excluding unnecessary documents from the export process. Your suggestions emphasize the importance of the system's capability to effectively filter relevant documentation, allowing for quick compilation during export.
Does this align with what you're looking for?
Paul
Principal  User Experience Designer (Upchain)
lho1
hi  @PualQuek
You are correct.
I have listed a couple of surgentions, I hope they make sence.  However I can see tha not evertything from option C got included.
Just to elaberate, then the idea is to filter in item types when making a bulk export. E.g when making a bulk export of an end item where assemblies and subassemblies is selcted in the filter, then all other items (manufactured, purchaed maechnical ect.) is not included in the bulk export.
Option C is not as good at option A or B as it is not that flexible.
PualQuek
Hi @lho1,
I am exploring two approaches:
  1. Have a toggle in both the cBOM and eBOM items that allows the system to recognize that the documents associated with each item are to be exported as predetermined by the user.
  2. During the export operation, allow the selection of associated documents based on the selected item to be exported.
I can provide more details with illustrations in a separate conversation if you like.
Paul
PualQuek
My apologies for the double posting.
lho1
Hi @PualQuek
Approach sounds optimal. I would love to see some illustrations :slightly_smiling_face:
DRueda_ARK
probably the most easy for this is create a connection with the API and get only the files with a custom property marked
