• Forums Home
  • Upchain
  • Upchain
  • Allow Check in/PDF translation creation of CAD when item is currently part of a Change Request
Welcome to the Upchain Ideas Board! Before posting, please read the helpful tips here. Thank you for your Ideas!
Create a Tenant property that allows users to Check in CAD if item is in a CR and in Development State when properties drawing.create.pdf is also on.
Currently it is not possible to check in CAD when drawing.create.pdf is on and the item is in CR, even though the item is in development state.
It makes no sense to me that updating a drawing is allowed but a translation of that drawing is not allowed. My only solution at the moment is to cancel CR or give all CAD users administration privileges.
Having a tenant property or a toggle in the drawing.create.pdf setting will fix this issue.
Related to limitation:
https://help.autodesk.com/view/UPCHN/ENU/?caas=caas/sfdcarticles/sfdcarticles/Operation-Blocked-Thes...
4 Comments
MatthewTGJNV
Community Visitor
Our Team is blocked until this issue is resolved. The inability to check in CAD files while in a Change Request is causing severe disruptions to our workflow. It's unacceptable that we can update drawings but are blocked from generating PDF translations. The proposed tenant property is essential—without it, we’re forced to cancel CRs or grant excessive admin privileges, both of which compromise our operations. This needs to be prioritized!
JLatOWI
Community Visitor
As noted above, this blocks effective use for one of the key reasons we have it in the first place. *Please* resolve this issue quickly. We have many new designs coming to completion and will need to have this capability when they do.
Thank you for your consideration.
keithQNYCR
Community Visitor
This is a critical issue that needs immediate attention! The inability to check in CAD files while in a Change Request is severely hampering our workflow. It’s illogical that we can update a drawing but not generate a matching revised PDF translation. The proposed tenant property is essential to resolve this. Please prioritize this fix!"
melissa496LB
Community Visitor
