Upchain Forum
Welcome to the Upchain Forum. Share your knowledge, ask questions, and explore popular Upchain topics.
Upchain attribute codes in Tables - Adding Backslash
7 REPLIES 7
Message 1 of 8
HansChristianFossum
164 Views, 7 Replies
When creating a table in my Inventor drawing template with Upchain attribute codes, backslashes are added to the code when creating a drawing based on the template.
This results in codes who doesn't work.
E.g. The code looks like {%03%} in the template and in the drawing based on the template the code looks like \{%03%\}
Se attached screen shots.
Labels (1)
7 REPLIES 7
Message 2 of 8
Hi @HansChristianFossum that is an interesting one! A few questions for you:
  • What version of Inventor are you using? Does it behave the same in other Inventor versions?
  • It looks like you're creating a sort of revision table. Does this happen when you enter codes into the title blocks or anywhere else in the template?
  • Does it happen when creating both IDW and DWG drawings from the template?
Cheers.
Message 3 of 8
Hi @emily.caulfield , I'm using 2025. Haven't been able to test in other versions.
I'm creating an ordinary table in Inventor, not revision table. It doesn't happen i the title block.
I have only tested it on idw's.
I made a work around creating an empty table and putting text with the codes on top. That works, but not ideal. I assume this is an Inventor issue, not an Upchain issue.
Message 4 of 8
Hi @HansChristianFossum yes it sounds like an issue with Inventor. I only tested the codes in the title block and didn't see this issue. I guess you'll have to use the workaround.
Message 5 of 8
@emily.caulfield should I duplicate this post to the Inventor forum?
Message 6 of 8
@HansChristianFossum yes I'd ask there as well to see what they have to say about it.
Message 7 of 8
@HansChristianFossum- I have the same problem in Inventor 2024. Did you find a solution?
One workaround that seems to work is to remove the table from the drawing template and manually copy/paste the working table from another drawing.
Message 8 of 8
Yes, a fix will be released soon.
Workaround: Create the curly codes outside of the table as ordinary text on top of the table. Not ideal, but it works.
