Is there an option/method to maintain SolidWorks part references when importing into Upchain?
As an example, I imported a part and its mirror, but the mirror did not maintain its link to the original part. Similarly, in-context features were broken during import.
I also have seen this issue. As far as external references go, you should only make external references after creating the part in Upchain. As far as I can tell, if you make a new part with external refs, then create an item, the references will always go out of context. As for mirrored parts, Upchain doesn't support them from what I've experienced - if you eventually need to clone a mirrored part you're going to see issues. It will let you create an item and it will look like it works initially, but it can cause problems down the line.
