Error message: "Duplicate Files" when updating the cBOM in Inventor
andre.roell
andre.roell
An assembly (a gearbox) was created, using the design assistant in Inventor to create some components of this assembly. This assembly is now to be registered in Upchain. When updating the cBOM, the error message shown in the screenshots appears:
"Duplicate Files:
Your assembly contains files with the same filename and filetype that already exist in Upchain. Rename the following files to add them to Upchain."
Within the Upchain database, other assemblies were also created and registered using the design assistant, which are identical in designation but differ in execution. However, these receive a unique part number upon registration, so the reason for this error message is not clear to me.
When an assembly or a component is created with the design assistant, a phantom assembly is created in Inventor in which the desired component is placed. The structure can also be seen in the following image.
The following has already been tested:
  • Renaming the affected assemblies --> No success.
  • Changing the assembly from phantom to normal --> No success.
  • Individual registration of the affected assemblies --> This worked, however, no connection to the actual overall assembly could be established and the error message remains in the overall assembly, preventing it from being registered in Upchain.
Is there a way to eliminate this problem and register the assembly as well as the associated subassemblies and components?
emily.caulfield
Hi andre.roell, apologies for not responding sooner. I'm not super familiar with the design assistant tools in Inventor. But is it possible that the parent assembly was still retaining references to the unregistered affected sub-assembly? This is sort of what it sounds like since you were able to register the affected sub-assemblies individually, but were faced with the error once you went back to register the top assembly. Does the assembly have a drawing that might still hold a reference to the affected sub-assembly? A couple other things to check:
  • Do you have the tenant property filename.pattern set to something other than ${originalFilename}? If not, then you need to make sure that every file that you register into Upchain has a unique filename.
  • Shared components are trickier. If you have registered something that you want to reuse in other assemblies, then you need to download the registered item and insert that into your unregistered assembly to avoid duplicating the same item.
If you are still facing issues, then I recommend submitting a support ticket.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
