I've been using AutoDesk Viewer (free online version) for a while now and recently found I can no longer select an object in a model then isolate it or hide it. When I select an object now and right click, it only gives me two options, 1. Show all objects, 2. Pivot. Has anyone else experienced this? I can still isolate or hide the object from the model tree but that takes much longer. I appreciate the input.
To select individual objects in AutoDesk Viewer, use the selection tool from the toolbar, then click on the specific object you want to highlight. You can also filter by object type or layer for more precise selection.
