Technology Administrator Forum
How to set Printer Support Path via registry for DWG True View 2025
1 REPLY 1
AutodeskCommunityUser
250 Views, 1 Reply
Hello Community,
We would like to rollout the Printer Support Paths in the DWG True View options via the registry. I have attached a screenshot of which paths are involved. Is this possible ? Our environment is a Citrix environment.
Can anyone help us ?
Erik
1 REPLY 1
Yes, you can add entries into the registry for DWG Trueview
The best approach is to update the registry keys manually, then right-click the General key and export it to a reg file.  Open the reg file with notepad remove everything else except the items you need...
