After installing Inventor 2024, the program won’t launch with the following error ‘Failed to initialize a component for accessing AutoCAD files. Please try again. Error 82.’
Help me!
Solved by AutodeskCommunityUser. Go to Solution.
Thank you that was very usefull,
C'mon Autodesk! Fix your installation software.
I installed process monitor to find what file is missing - see screenshots.
and indeed My Inventor 2025 gave me those error after installation:
Failed to initialize a component for aqccessing AutoCAD files.
Please try again.
Error 16
What was needed was to manually create file:
c:\Users\kleme\AppData\Roaming\Autodesk\Inventor 2025\RealDWGSettings.xml
And add this content to it:
<?xml version="1.0" encoding="utf-16" standalone="no" ?>
<RealDWGSettings InstallDirectory="C:\Program Files\Common Files\Autodesk Shared\RealDWG Shared 2025"></RealDWGSettings>
wow! i open the notepad, copy paste your code, save code in .xml and put in the file on location, and then i opened the software, IT WORKS! i struggled to figure out this problem for a day. good solution, man! liked ![]()
