Technology Administrator Forum
Error when installing inventor 2024 - Error 82
24 REPLIES 24
Message 1 of 25
AutodeskCommunityUser
1175 Views, 24 Replies
z4322704442880_55b7678a74a99f63519c57a2d93444b5.jpgAfter installing Inventor 2024, the program won’t launch with the following error ‘Failed to initialize a component for accessing AutoCAD files. Please try again. Error 82.’
Help me!
24 REPLIES 24
Message 21 of 25
It worked. This really is the solution to the problem
Message 22 of 25
Thank you that was very usefull,
C'mon Autodesk! Fix your installation software.
I installed process monitor to find what file is missing - see screenshots.
and indeed My Inventor 2025 gave me those error after installation:
Failed to initialize a component for aqccessing AutoCAD files.
Please try again.
Error 16
What was needed was to manually create file:
c:\Users\kleme\AppData\Roaming\Autodesk\Inventor 2025\RealDWGSettings.xml
And add this content to it:
<?xml version="1.0" encoding="utf-16" standalone="no" ?>
<RealDWGSettings InstallDirectory="C:\Program Files\Common Files\Autodesk Shared\RealDWG Shared 2025"></RealDWGSettings>
Message 23 of 25
wow! i open the notepad, copy paste your code, save code in .xml and put in the file on location, and then i opened the software, IT WORKS! i struggled to figure out this problem for a day. good solution, man! liked :thumbs_up:
Message 24 of 25
No way! thank you so much bro.
Message 25 of 25
i love you 4ever broooooooooooo
