Cannot login. Pressing button only shows short animation. Nothing happens.
AutodeskCommunityUser
Autodesk Autodesk
Trying to login to my Autodesk account. Pressing button only shows short animation. Nothing happens.
Using the  web button in Fusion data panel works. I then can click my way to your other websites and I am still logged in. Can use that as a work around. But using the normal route to login does not work. Also tried on my Samsung mobile and it does not work.
Erik W
I found the solution. I changed password using the change password button and now the login works as it should. Please note that it did not in any way tell me there was a problem with the password I entered before.
