Technology Administrator Forum
Cannot login. Pressing button only shows short animation. Nothing happens.
1 REPLY 1
AutodeskCommunityUser
262 Views, 1 Reply
Trying to login to my Autodesk account. Pressing button only shows short animation. Nothing happens.
Using the  web button in Fusion data panel works. I then can click my way to your other websites and I am still logged in. Can use that as a work around. But using the normal route to login does not work. Also tried on my Samsung mobile and it does not work.
Erik W
1 REPLY 1
I found the solution. I changed password using the change password button and now the login works as it should. Please note that it did not in any way tell me there was a problem with the password I entered before.
