Now Available! Updated Excel & Revit Add-in's
This is just in! Autodesk Tandem has released updated versions of our Excel and Revit Add-Ins. They are available for download from the Autodesk Knowledge Network site: click here for Excel and here for Revit.
Don’t forget to review these pages in their entirety as they contain the latest and greatest information about these add-ins.
For the Excel Add-in, users may have to add Autodesk Tandem as a Trusted Publisher. To do so, follow the instructions below.
- To check if Autodesk is listed.
- From the File menu, click on Options (at the very bottom).
- Open Trust Center, then Trust Center Settings…
- Click on Trusted Publishers. If Autodesk is listed, then you should be all set. If not, continue with these instructions.
- Open Add-ins
- From the Manage drop-down, select COM Add-in. Click Go
- Select Tandem.Excel. Click ok
- Close Excel, and open the File explorer.
- In the navigation bar, enter the following:
- Open the Microsoft folder, then Add-ins, Autodesk, and Tandem.
- Find the file titled Tandem.Excel.dll and right-click to open the Properties.
- Navigate to the Digital Signatures tab, select Autodesk, and then Details
- Click on View Certificate, then Install Certificate…. The Certificate Import Wizard will open.
- Select Local Machine, Next, and click Yes.
- Click on Place all certificates in the following store, then Browse and select Trusted Publishers file.
- Click ok, Next, and then Finish.
- Close out of all the Properties windows and open Excel
- Go back to the Options sections, Trust Center, Trust Center Settings, Trusted Publishers, and Autodesk should be listed.
- Repeat steps 2 through 4 from above.
- Click ok, and the Autodesk Tandem tab should appear in the ribbon.
Jessica Smith
Content Marketing Specialist, Autodesk Tandem
Autodesk Tandem | Subscribe Now! | Autodesk Tandem Resources
