Now Available! Updated Excel & Revit Add-in's
jessica_smith
jessica_smith
This is just in! Autodesk Tandem has released updated versions of our Excel and Revit Add-Ins. They are available for download from the Autodesk Knowledge Network site: click here for Excel and here for Revit.
Don’t forget to review these pages in their entirety as they contain the latest and greatest information about these add-ins.
For the Excel Add-in, users may have to add Autodesk Tandem as a Trusted Publisher. To do so, follow the instructions below.
  1. To check if Autodesk is listed.
    1. From the File menu, click on Options (at the very bottom).
    2. Open Trust Center, then Trust Center Settings…
    3. Click on Trusted Publishers. If Autodesk is listed, then you should be all set. If not, continue with these instructions.
  2. Open Add-ins
  3. From the Manage drop-down, select COM Add-in. Click Go
  4. Select Tandem.Excel. Click ok
  5. Close Excel, and open the File explorer.
  6. In the navigation bar, enter the following:
  7. Open the Microsoft folder, then Add-ins, Autodesk, and Tandem.
  8. Find the file titled Tandem.Excel.dll and right-click to open the Properties.
  9. Navigate to the Digital Signatures tab, select Autodesk, and then Details
  10. Click on View Certificate, then Install Certificate….  The Certificate Import Wizard will open.
  11. Select Local Machine, Next, and click Yes.
  12. Click on Place all certificates in the following store, then Browse and select Trusted Publishers file.
  13. Click ok, Next, and then Finish.
  14. Close out of all the Properties windows and open Excel
  15. Go back to the Options sections, Trust Center, Trust Center Settings, Trusted Publishers, and Autodesk should be listed.
  16. Repeat steps 2 through 4 from above.
  17. Click ok, and the Autodesk Tandem tab should appear in the ribbon.
Jessica Smith
Content Marketing Specialist, Autodesk Tandem
Autodesk Tandem | Subscribe Now! | Autodesk Tandem Resources
Replies (7)
Yien_Chao
Hi Jessica,
thank you for the instruction.
i've done everything as describe, but my Excel addin has no icon and the sign in dont work.
any idea to fix this?
best
jessica_smith
Hi @Yien_Chao , what happens after you sign-in?
Jessica Smith
Yien_Chao
hi Jessica,
well, nothing happen after
sign-in.
i also tried to reinstall. same.
Y
magne.ganz
I am running into same issues. The add-in is visible, but buttons are "disabled". Clicking "Sign in" does not lead to any action. Nothing happens.
jessica_smith
@magne.ganz do you have administrative permissions to your machine?
Jessica Smith
magne.ganz
Yes, I have local admin permissions on my machine.
The MS Office is 64-bit
I have followed the steps above.
The add-in appears, but all buttons are disabled.
hariQMX5A
Observer
Observer
I also have the same issue, the icons are also not visible.
