Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Release Notes
We are happy to announce the support of Discrete Values in Autodesk Tandem. Now, our users can visualize string data in their digital twins, expanding the data support offerings for sensors.
Thank you very much team for this.
It now opens up a whole data trove that I have been waiting to explore and implement. In fact, I've been holding off on the purchase of some sensor that produce this data until it was available in Tandem.
In charts with discrete values, can the colours be permanently customisable?
The use case being that certain values might be viewed negatively, and so you might want to use an appropriate colour like red. While other values might be viewed positively and want to use other colours like green, blue.
A couple more questions.
I can appreciate that some Discrete Parameters might need very specific values defined, almost like a filter. But in other cases, I want all values.
When I tried not defining the values I kept getting errors. So if the above is possible, some guidance would be very welcomed.
Thanks.
The list of acceptable values must be defined up front because we map the textual representation to something more compact for storage. All unknown values will appear in the same way (they won't be visualized in a distinct color, etc).
The use case you mention is well understood and reasonable, but not currently supported by our implementation -- it will require further work in our backend to support which we have not yet planned.
