Difficulty in Separating the data from Sensors
We are new to using Tandem and have been struggling with integrating the sensor data into the model. We are using disruptive technologies as our host for the sensors and we are able to assign hosts in Tandem, and the data is being sent into the connections in Tandem which we are able to pick from in the connections. The main issue we are having is that when a new sensor connection is added eg. temperature, then all temperatures seem to end up with the same values, so we have for instance 10 temperature or co2 sensors showing the same data in Tandem. We had added the http links and added the tandem key with associated value in Disruptive for each sensor, and we can see each sensor labelled in Tandem in the payloads, Tandem just seems to default to use the same value and this happens when separate parameters are set up for each sensor as well. We tried the video but could not follow part of it and in any case, we could not add all sensors as the data connectors were maxed out on Disruptive. If anyone could provide any helpful tricks or tips it would be appreciated as this is all very new to us and we are very keen to make our digital twin as functioning as possible. Many Thanks
