Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Configure connection disabled
shweta_raut
Observer
Observer
shweta_raut
Observer
Observer
I'm using tandem for data streaming. While the asset connection is done I'm unable to configure the connection so far as the configure connection is disabled. Also the classification of Elements needs to be done manually as the added facility is of autodesk plant3d and imported model is .ifc. How to resolve this disabled configure connection option.
the above image have the configuration option disabled don't know why this issue.
AdamPeter
Hello and thanks for the great question! Each of your connections will need to have a classification assigned to it. The classification that is assigned should have parameters of the expected data type that will be incoming.
For example, I have a connection called "Main Floor" and is classified as Docker Thermostats.
In the facility template you use, that classification will have each of the parameters that you want to stream.
You can also find out more from the Tandem Help Page
Adam Peter
Customer Program Manager
