I have a pair of Ecobee thermostats at my house that I've been streaming into Tandem for some time now. I thought it might be interesting to share that by using the combined charts I can see my upstairs temperature runs warmer by about 2-3 degrees but downstairs my humidity tends to run higher by a surprising 7-9%. I already run a dehumidifier in the basement, but I need to manually empty it. The chart shows I probably need to do that more often or run a drain hose from it!
As an experiment I've also thought about adding a vibration sensor to the humidifier, streaming it and adding a threshold so I can visually see in Tandem when it's not running. I'd love hear other ideas too!
Likewise, but for an office environment. In this example I have an Office connection for the mean value. This can help with identifying spikes for individual spaces. It would be good if Tandem could have a toggle to show mean values on combined charts and individual charts for that parameter type, and to show it with a different line style.
A couple of thoughts come to mind when viewing this data.
Other examples that come to mind, from an occupant's perspective:
This is really good feedback @Chad-Smith! Your comment about showing mean value or average over time is well received. While we don't have anything out of the box in production the Tandem TestBed (REST) API will allow you to export 30 days of stream values so in theory you could export that data, run a calculation and then stream the calculated value back into Tandem as a new parameter. The is also a good plug for people to join the Insider Lounge as the Tandem Connect beta also helps facilitate the above workflow.
