I deleted all of the standard view renderings that Fusion does for you once you save for the first time in order to update the renderings with my current model setup.
Fusion hung once clicked the delete button on the last image. Window's Task Manager didn't say that Fusion of unresponsive. Buttons in the top right corner (minimize, maximize, and close) didn't work. Right clicking the icon in the toolbar at the bottom of the screen and clicking close, did nothing. In the end I had to go into Task Manager and do the End Task operation.
Solved by colin.smith. Go to Solution.
Hi @colin.smith,
I'm not sure I understand what you mean by what the "state" of Fusion was when I restarted, but from what I can remember, Fusion seemed to be acting fine after a restart. All the standard images were queued up to be rendered. I don't think I had to anything additionally special to get the standard renders rendered.
I just thought this hang of Fusion was odd because I've done the same procedure in other Fusion projects, and did not have any issues. Part of me wonders if it was because I was going through and deleting the standard renders too quickly for the whole Fusion-Cloud process to keep up/work. Although, that seems unlikely...
