lisp icons
lisp icons
you can update the lisp coding as toolbars icons, people can easily access everything bcz mostly wipeout and purge, Aduit overkill commands are using daily basis.
Praveen Kumar
1 Comment
pendean
Community Legend
@Praveen.KumarLRRH5 Customizing the RIBBON and adding Panels is provided in many free tutorials online, please explore and help yourself. Post back if you actually get stuck, but I suspect you'll find it easy to understand and follow.
You can also just add command to the QAT bar from the RIBBON with just a right-click too, give that a try.
