I would like to mention that we're struggling to remove a version of AutoCadLT when you have versions AutoCad LT 2024 and LT 2025 running in a "side by side" mode , but you just need to remove LT2024 to save some space, then your LT 2025 stop working because you just uninstalled many parts of your Autodesk Licensing without the options to repair it. We're currently on this dilema, as about 100 users have this scenario in a Production environment and we need to remove only LT20204. As they can't remove it by themselves, because of the lack of admin rights it will also be not possible remoting those machines if it will break LT2025 when manually uninstalling LT2024.
With the Windows Troubleshooter tool that's not a tool we're allowing on our secured environment, I can't even think if all this users may need to re-image their machines because a piece of software can't be correctly uninstalled?
I thought that Autodesk had some innovative way's to produce a Removal Tool that will prevent this kind of cases, since both applications can be installed side by side. And if this will not be the case or if it breaks functionalities between versions, then don't allow the "side by side" on future versions, and we will fully migrate to the newest version every time, instead of dealing with issues every single version, or provide a smart clean-up tool that will target only the version we need to remove.
Reference:
https://forums.autodesk.com/t5/installation-licensing/autocad-2024-uninstallation-dilemma/m-p/126732...
