Trying to switch to subscription
When trying to switch from a multiuser license to a single user on subscription I am having issues.  I followed all the directions here:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to...
When I restart the software, I only get the option to select multi user.  After multiple re-boots and restarts, I got the notice that I was not connected to the internet.  However, that is not true. I can access multiple websites.
When I call IT, they are going to tell me I have internet access.  Has anyone had this issue before and were you able to fix it?  How?
Is there some special port or IP address I need to make sure I have access to?  Our firewall is the stuff of legend.
It is all version 2020 - Vault Pro and AutoCAD with specialized tool sets.
I reached out to the help desk and it got elevated to a specialist but I have not heard back and its going on 24 hours I cannot use the software.  Getting a little frustrated.
mdavis22569
Unfortunately this is a common set of issues ...
How to set up antivirus (AV) exclusions to improve stability and performance of Autodesk software
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Are-there-antivirus-excl...
Which URLs/Protocols need to be white listed for Autodesk Subscription Licenses
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/What-U...
About the missing Sign In Subscription option:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/No-Let...
Connect to the internet message:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Connec...
Mike Davis
Tiana_Y
Hi @Anonymous,
I just wanted to check in with you and see if the information that @mdavis22569 helped you out? If not, did you hear back from the technician wou were working with? If you have a case number I can look it up for you.
Best,
Tiana.D
Community Program Manager
Contact Autodesk Support
@Tiana_Y  no one from autodesk reached out to me.  I had our IT department work on it and they were able to make some changes that allow it to work.
