Switching named user licences
murphycolinp
Message 2 of 10
murphycolinp
Hi,  We have numerous users using AutoCAD, but some LT and some full AutoCAD. Does the new licensing model allow you to change the user from LT to full for a specific project then change back to LT at the end of that project? I know I can physically do this, but do Autodesk allow this?
Replies (9)
Message 1 of 10
murphycolinp
Message 3 of 10
pendean
Community Legend
Community Legend
You are violating forum rules by posting the same thing over and over in many forums.
Your other post was moved to the correct forum, now sit on your hands and wait for a reply:
https://forums.autodesk.com/t5/installation-licensing/switching-named-user-licences/td-p/9557331/jum...
Message 4 of 10
AllenJessup
AFAIK You can change the assignment of the licenses as often as you like. If you have all your full AutoCAD licenses assigned. You will need to take a full license away from one user in order to assign it to another user. So there will be a bit of juggling involved. But I don't see any reason it wouldn't work.
Allen Jessup
CAD Manager - Designer
Message 5 of 10
Mark.Lancaster
@murphycolinp
As long as you have the required quantity of license this is allowed.   But that means both software needs to be installed on the machine.
Mark Lancaster
Message 6 of 10
murphycolinp
I only posted in 2 forums, not "many", as there was no specific forum i could see relating to this topic. Not sure you're tone is very helpful but thanks for the information anyway.
Message 7 of 10
lena.talkhina
I have merged both threads in one and unmarked your post as a solution.
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
Message 8 of 10
lena.talkhina
Hello @murphycolinp !
Let me check in internally on your question. I will come back as soon as I can share anything with you.
Message 9 of 10
murphycolinp
OK, thanks.
Message 10 of 10
lena.talkhina
@murphycolinp ,
An admin can unassign and reassign whenever decided, as long as you have the number of subscriptions do not exceed the number of users who need access. For example...if I have 5 AutoCAD subscriptions, I can have no more than 5 users assigned to those subscriptions at any given time. but if project needs change, I can unassign and reassign to another user. For example... if Lauren needs AutoCAD LT for one project for 3 months, at the end of that project, she can be assigned AutoCAD instead for my next project, as long as I have a subscription available.
Usage reporting also makes it clear when I have available subscriptions to assign.
