Student Room
Welcome to the Autodesk Student Room. Join us to learn about the latest industry trends, connect with other members, showcase your work, and more.
Student Access to Autodesk Revit 2023
7 REPLIES 7
Message 1 of 8
alexandarhayat
859 Views, 7 Replies
Hi , can anyone guide me, I have my Student account access to Autocad 2023, but can't have subscription for Revit 2023 while I have installed it through my Student account. Can a student account have subscription to multiple Autodesk Products simultaneously?
7 REPLIES 7
Message 2 of 8
Hi @alexandarhayat,
You can access all of the products on the Education Products Page - you're not just limited to one!
I would recommend downloading Revit 2023 again as the process which assigns the license to your account is triggered when you download the installer. You don't need to reinstall.
The next step would be to check https://manage.autodesk.com/products which lists all of the products you have access to. If it still doesn't appear, contact educational support - feel free to link to this post to show what you've tried already.
Please 'Like' posts that are helpful. If a post answers your question then feel free to click the 'Mark as Solution'
Leo Warren
Community Manager - Students & Educators
Are you a student? Come join our Student & Educator Community! | Education Knowledge Base | Rules and Etiquette
Message 3 of 8
Yes, you can download multiple software's. And not just limited to 1.
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
Message 4 of 8
you have already educational license or not? if no, you have to be eligible to educational License
if yes, please try to download it again without installing and check email sent with congratulations and also it will appear in your products in manage.autodesk.com
 and you can watch this screencast in Arabic language so that follow the steps
for part two of the question is yes you can have access to muliple products at the same time such navisworks, AutoCAD,Revit,Civil 3d ....etc.and also you can have access for the same software versions such 2023 ,2022,2021 and 2020.
each Educational license have one seat for all Autodesk Softwares
Elmoataz Bellah Salem
AEC Technical Specialist | Autodesk Expert Elite | Autodesk Ambassador Gold Level | ACP | ACI
Message 5 of 8
Actually I haven't download the 2GB setup file for Revit 2023, I have click on the Install button to get the Revit via by Student Account. And I have tried multiple times to reinstall it. But every time I got the same issue that no active Subscription is available against my email for the Revit 2023. So should I download the 2GB setup file?
Message 6 of 8
kindly attached screenshot of the message that appears @alexandarhayat
Message 7 of 8
@alexandarhayat
to be at the same badge, you have already access to educational licenses ??and we go to https://www.autodesk.com/education/edu-software/overview  and sign in the following message appears and informs that you eligible to Autodesk Educational Licenses.
Message 8 of 8
Thank You, I have uninstalled and then re-installed the product and got activated .....
