Student Room
Welcome to the Autodesk Student Room. Join us to learn about the latest industry trends, connect with other members, showcase your work, and more.
creating a ramp in revit structural
1 REPLY 1
joseph.hyukyun
195 Views, 1 Reply
hi everyone, i am new to revit i have a little problem in it, if anyone can help me please i wanted to create a ramp using floor to analyse it in robot after that, but after offsetting the slab the analytical model doesn't follow the slab any solution?? trying to do it with the slope option but instead i cant change the shape of the slab at the start/end to be parallel to the floor
(btw i dont want to use the ramp command because it doesn't show in analytical model)
if anyone can save me i am so thankful
Labels (2)
1 REPLY 1
ruyraoli
in reply to: joseph.hyukyun
Hi @joseph.hyukyun
To perform analyzes either on the robot or on any other tool as far as I know you need to draw the ladder, it cannot be a ready-made option from revit. Use the draw command.
Você achou uma postagem útil? Então fique à vontade para curtir essas postagens!
Sua pergunta obteve uma resposta que resolveu a duvida? Então clique no botão Aceitar Solução.
Rui Raoli
Eng. Civil Esp. em Design de Interiores e Iluminação | Gerente BIM
