Hello everyone, some things confuse me about influence surfaces and load optimizations.
Here is my 3D bridge model:
I plan to separately design the beams for each span for minimal reinforcements. The plan is for the beams to be designed to handle the worst case of design traffic considering an AASHTO LRFD 7 specifications for a design truck, design tandem, and a special permit vehicle. I believe load optimization finds the worst case for you, which I hope is correct. This brings me to my main question:
When I choose an influence surface, do I have to do it for every single beam I design, or will one selection do? Is it correct to pick the beam I am currently designing for the influence surface generation?
After the influence surface generation, I noticed that the load optimization has different options available.
My own country (based on AASHTO)'s codes require the checking of the worst of:
1. Design truck + lane load
2. Design tandem + lane load
3. Two design trucks with 90% load + lane load
However, I am having a few problems.
First, my country's design truck and tandem are a bit different from AAHSTO's, but only through the numerical values. I thought I could just define them as custom permit vehicles, but it appears that Load Optimization uses the default anyway, and the custom vehicles have errors where one axle went missing. So I was wondering if I should just edit the numbers on the Structural Loads and if that would still be the optimal.
Also, I do not know if the two 90% design trucks are not happening because the program does not account for them or because they are exceeded by other load combinations. I have ticked the box that said double design truck, so I think it was accounted for, but I want to make sure.
Lastly, is this something to worry about?
I get the feeling that only one of the 5 beam elements is being optimized for. Also, I do not know what to make of the other options. What does it mean when I tick/untick overhang? Finally, what do the options in the drop downs mean?
Thank you so much, any input will help.
