Shear Check - VRdmax not calculated
kaiwing.wong
kaiwing.wong
Hi there, I would like to ask what is the reason why ASBD is not calculating the VRdmax. Kindly refer to the snapshot for the reference.
Currently using ASBD 2020 version.
dave_geeves
Hi, thanks for including the version number and great screen shots. A very interesting question. It may have been corrected in the latest version but I can't test this without a data file. Could you please zip your data file up and attach it to a reply so that I can investigate further. Thanks.
Dave Geeves.
kaiwing.wong
Hi, please find attached the zip file. Thanks.
simon_hooper
Thanks for the file.
Upon investigation, one of the NDP values is set to zero in your file, causing the shear strength to be set to zero!
To fix this, go to Nationally Determined Parameters EN1992-2, Clause 3, 3.1.2(102) Maximum concrete class for shear CMax,shear and set to a suitable value, e.g. 50MPa.
For EU+UK, shear strength is limited to CMax,shear.  Since it was set to zero in your file, VRd,max ended up as zero.
We will add a check to ensure the shear strength is taken as the concrete strength, if CMax,shear is not set, in a future update.
Simon
Simon Hooper
Software Development
kaiwing.wong
Thank you for the solution! The problem solved.
Jason.LauSLF4C
Community Visitor
Community Visitor
Hi Simon,
I am facing almost similar issue as the above.
I have counter checked with the method that you have provided, however the value for my Vrdmax is slightly differ.
Is it possible if you could assist me in resolving this matter under the case of "ULS Max Vy".
As attached is also my sbd file.
simon_hooper
Hi Jason
Thanks for supplying your file.  What exactly is the issue that you are seeing?
For loadcase SL5, V_Rdmax on the form matches the printout, which seems correct calculation (in 2023.0.2.100).
Simon
Simon Hooper
