Message 1 of 9
08:20 AM
I attempted to check a reinforced concrete section. After a few iterations, I noticed that the crack width under Quasi-permanent never changes and it considers the stress in the steel to always be 400N/mm2. I tried changing the load combinations, even removing all loads and analysing an empty load case, but the steel stress was still 400N/mm2.
Is there a way to control the stress in the steel for crack width calculations or the software only calculates the maximum crack width at section (steel) failure?
