Precast Girder Design
paul_leeQ2EQ8
Observer
paul_leeQ2EQ8
Observer
Observer
Hi @dave_geeves,
I'm quite new to the software, so I'm still trying to understand the user interface and design procedure. Anyway, I have a fairly standard question that I hope you can assist me with. Basically, I'm attempting to analyse and design a precast-pretension U-girder with a cast-in-situ topping. The girders are not supporting traffic loads. Only additional SDL and LL after casting of slab topping.
The construction sequence is standard.
1. Precast-beam hoisted into position
2. Casting of slab topping
3. Additional SDL+LL applied.
Could I get advice on how to.
1. Generate custom loads (I tried adding this to "Structure Loads" tab but don't know how to export those to "Design Beam")
2. Review load combinations (Ideally I would like to be able to review and change/or create custom load combination. I.e, remove temperature load for example.)
3. Sequence the load application/construction stages.
dave_geeves
Hi Paul,
Sorry for the delayed response and thanks for sending your data file with the query.
I have looked through your project file and it looks like you have understood the process and workflow ok. I'm not sure if I fully understand your questions so the following answers may not be exactly what you want:
  1. If you create custom loads (I assume Load case 3 called Live Loads) in the line girder structural analysis, you will transfer them by solving the load cases (outside of the automated loading) and then transferring the resulting effects to the Prestressed Design beam load table in a similar way to transferring the automated results, by opening the transfer loads table (Menu > Calculate > Transfer Results) dave_geeves_0-1713897540798.png
  2. It is not really possible to review customised load combinations in the Design Beams as the design combinations defined in the design standards are already built in and use a variety of linear combinations of the basic load case results tables.
  3. The staged construction is defined in the Prestressed beam module such that the beam load tables reflects the stage construction effects.  This only has a real effect in the design of service loads where the build up of stresses reflects the stages defined in the beam definition.dave_geeves_1-1713898350273.png
I hope I have some understanding of your issues and if this has answered your query please mark my reply as a solution so that others may benefit.  My apologies once again for the delay.
Kind regards
Dave Geeves
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
