Solved by david.geeves. Go to Solution.
Hi Ediriisa,
Thanks for this interesting question. Autodesk Structural Bridge Design is a structural analysis and code checking software so does not contain detailed 3D model information that I think you are looking for in Civil3D. However you can create complex 3D analytical models in ASBD and export them as lines and faces into s DXF file, which of course can be imported into Civil3D. The coordinate system may not be consistent but I'm sure that can be addressed.
I hope this helps
Kind Regards
