Missing toolbars
Missing toolbars
Missing toolbars
I've installed ASBD 2019 on a Win 7 pc and the toolbars display correctly, as per the Correct Toolbars.jpg.  When I installed on a Win 10 the toolbars display different, as per Incorrect Toolbars.jpg.
Any ideas, thanks in advanced.
Steven Houghton
dave_geeves
Hi Steven,
I have been running ASBD 2019 on a Windows 10 platform for some while now and have not experienced the same problem.  It may be that the registry for this installation has become corrupt in some way so I suggest that you try the solution from a previous post with a similar request.
If this works ok please mark this post as a solution so that others can find a solution more easily.
Kind regards
Dave Geeves
karoly_tarcsi
Hi Steven,
Did you manage to overcome your problem?
Best regards,
Karoly Tarcsi
Software Development
(If you are satisfied with the answer, can you "Accept Solution ", so others can learn from it. Thanks.)
Karoly Tarcsi
Yes, after deleting the registry key the toolbar displayed correctly.
Thank you for your help
Steven Houghton
