Will all the dead loads added under the beam loads be considered in the PE for the prestressed beam analysis?
Yes, I believe all the Permanent Effects are included from the appropriate "Beam Load" tables. You can see what is included in the "Summary Of Applied Loadings" section of the printed results:
In my example I have checked the values against those of the loading tables and they do correlate.
I hope this helps, and if this has answered your query then please mark my reply as a solution so that others may benefit. Thanks
Kind regards
Dave Geeves
