Hello, I have updated my ADSB to 2022, and not PDF view doesn't work any more. I have got JAVA reinstalled by IT; see the error message below. has anyone else had this issue? if so how do I fix it?
There have been other posts about Java in the ASBD Forum which can find using a search on "Java". Try having a look at this one here. If you have Java installed locally in the default location ther shouldn't be a problem but if it is in a non default location then you will need to specify the path on the Options->preferences data form.
Check this out to see if this will fix your problem. If not you will have to lodge a support case with Autodesk as it is a bit beyond me.
Kind regards
Dave Geeves
hi, Dave thank you for the quick response. I just clicked the "Reset Application Settings" and reopened the software and it worked away great. Thanks.
Hi, I tried enable the Java Path under both the 2022 and 2023 version, but none of the version is working, therefore, I wonder if you could provide further assistance/direction regarding this matter? Is there a specific Java Path required for the software?
Kind Regards,
Screenshot below:
