06:53 AM
I am assessing a continuous three-span steel/concrete composite bridge deck.
The deck has been modelled using a 3D shell finite element slab with the main steel composite beams inserted as FE web beams. Cross girders, concrete upstands and diaphragms have been added as beam members.
There are only vertical loads applied to the deck model. However, I am getting horizontal reactions at the fixed support, which I didn't expect, as there are no horizontal loads. Could you please advise why these horizontal reactions appear?
Sonia
