export from revit to autodesk structural bridge design
hernan825
hernan825
Good morning, I have a query. the model that I have in revit I can take it to structural bridge design
karoly_tarcsi
Unfortunately, at the current stage of the software, there is no workflow between ABSD and Revit.
You can import structures to ASBD by defining sub-models and pasting joint coordinates into the "Define Sub Model Members" form. See attached screenshot.
However, we have been heavily involved with integrating ASBD with Infraworks to create a smooth workflow for engineers and leverage the strengths of ASBD and IW.
Would you be interested to learn about it?
Karoly Tarcsi
Software Development
(If you are satisfied with the answer, can you "Accept Solution ", so others can learn from it. Thanks.)
Karoly Tarcsi
hernan825
tahnks for the answer, and yes interested to learn about it
regards
Jorge Bolivar
karoly_tarcsi
Hi Jorge,
Can you tell me about your organization? What projects do you use ASBD for?
Our top bridge guy regular visits key customers in person, and he gives online demos too. I will inform him as soon as I know a bit more.
Perhaps we should continue in private messages.
Karoly Tarcsi
Karoly Tarcsi
