Error: unable to open URF File and the model does not run
mohamed.zakir9GETY
mohamed.zakir9GETY
Hi, After undertaking the auto load compilation and further when I ran the analysis an error message stated "unable to open URF File: (see attached) and the model does not run and aborts the analysis. please could you assist me with this error.  SBD - Error.JPG
Replies (13)
dave_geeves
could you please provide your data file so that I can try to re produce the problem.  You will need to "zip" it up into a compressed folder before attaching it to a reply to this thread.  Thanks.
Kind regards.
Dave Geeves
fescobarEAZGF
Observer
Observer
I'm having the same problem right now. @dave_geeves could you check it out? @mohamed.zakir9GETY how did you handle the situation?
fescobarEAZGF
Observer
Observer
here's the file
dave_geeves
Thanks for attaching a data file.  I noticed from the file properties that this was created using 2025 version of the software so I was able to use the same version to test.
I didn't get the same error as the original post (unable to open URF file) for the structure failed to analyse due to a "Core Overflow" error. This is because the default memory allocation parameters are too small to handle a structure with over 20000 degrees of freedom.  These parameters can be changed from the "Options" menu as shown below:
I had to increase the database and core parameters quite significantly to get a solution (and they may need increasing further with an increase in the number of load cases.  However, this seemed to get a solution for the two load cases provided and the results looked as I would expect.
If this is not the problem you are experiencing and the original error message about not being able to open a URF file is the one, then I can only think that this may be due to a possible system limitation on file size or that you have insufficient access to the location the program is writing to.  Let me know.
I hope this helps.
Kind regards
Dave Geeves
fescobarEAZGF
Observer
Observer
@dave_geeves I've just allocated up to 1500MB database memory and 900MB core memory(default was 25MB). Then the following message appeared: "Total memory allocation exceeds limit". I'm not quite sure about how to overcome it, actually. Glad to know that it is not a modelling issue though.
No ideas about how to minimize DOF's at the moment, once it is only one span of a 320m bridge, with a roadway and a train line passing over...
Anyway, thank you for your time. I really appreciate your help and will be even more grateful, if you have any insights on how to deal with the (new) problem!
dave_geeves
The error message suggests that the memory request of 1.4Gb is more than the available virtual memory for your computer (which can be adjusted under system settings if there is sufficient disc space available).  However, these values are larger than anything I have used before and will certainly slow the analysis down.  Personally I would look to reduce the size of the model by reducing the number of transverse and longitudinal members. I generally find that accuracy is acceptable if there are 10 to 15 members in the span length. Transversely I would have just 2 finite elements between the main girders as this will give an acceptable representation of the shear lag effect in the slab between girders and a reasonable representation of transverse bending. This reduction would give a more workable solution for global effects.  Local bending effects in the slab may not be quite so accurate but this is often carried out as a separate analysis of a small area and the effects added to the global effects.
I assume that the span is 32 m rather than 320m as the latter would be quite impressive.
I hope this helps
Kind regards
Dave Geeves
fescobarEAZGF
Observer
Observer
I appreciate your thoughts about it and will definetly proceed with a small sensitivity analysis as soon as I get some time... I finally was able to simulate the file with a sturdy PC, and it worked well. 1/10 of span looks like a sweet spot for the start of the analysis.
About span size, 360m is the total span. The idea of this study is to provide information for a DEA of span lenght / material consumption.
Once again, thank you for your time.
KR,
christina.ayriss
Observer
Observer
Hi Dave, I'm having the same URF issue. I've tried increasing the memory and reducing the number of loadcases but I'm still getting the error. I'm using ASBD 2024. Thanks
christina.ayriss
Observer
Observer
@DaveGeeves I directed the message above to the wrong person. Please can you help with the URF error?
dave_geeves
Hi Christina,
Thanks for attaching your model. It appears that your model contains linked design beams related to the parapet) which have not been included in your zip file, so I can't test it.  Can you please attach these files  in a zipped folder, so that I can investigate.  Thanks.
Dave Geeves
Rafal.Gaweda
Autodesk Support
Autodesk Support
It seems the issue is fixed in SBD 2025.
Rafal Gaweda
gregorypajot
Observer
Observer
(sorry for my english, i'm french)
I've got the same problem with the file attached, or any new file i create. Older ones are OK.
It's not a memory problem, subjects are smalls.
It seems like a right autorisation but i work as administrator.
Can someone help me please ?
simon_hooper
Hi Gregory
I didn't get the same issue (both influence analysis and linear analysis worked fine).  First, I would restart you machine (maybe there is a locked file).  If that does not work, I would rename project file (save as...) and try again.  Does the same situation occur with another model, e.g. one of the tutorial files?
Simon
Simon Hooper
Software Development
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
