Composite curved bridge
Message 1 of 11
I am modeling a single span  composite curved bridge and I would like to kindly seek your advice regarding:
1. Which is the best way to model the beams the FE web or Offset Beam considering the vital need to incorporate the bracing into the static and dynamic analyses? What about the bracing element type? I used the design sections for the bracing and then assign these sections to the beam element.
2. How to ensure that the braces are connected to the steel beams?
Thanks in advance
Replies (10)
Message 2 of 11
Hello, I have improved my model.
I model the steel beam as a composite beam and then assign the FE Web. For the braces, I create a 3D submodel drawing the member elements at the same point created by the mesh of the design beam. I used the design sections and then assign these sections to the beam element.
At this point I think the model works well, the only concern is the Torsion Constant.
I can't perform the analyses because of the Torsion Constant. I have tried to change the grid torsion size 100x200 but the analyses do not perform yet. An error is occurring but  I can't understand what happened.
Also, I try to  add to Section Properties / Advanced beam properties/ Modify torsion constant, i put here the
(M Torsion  of the beam+0.5*Mtorsionof slab)  but no result
Please could you have a look at my model?
Thank you in advance
Message 3 of 11
dave_geeves
I was looking at your original post over the weekend and I did compose a reply regarding some recommended practices, but you made a second post before I actually posted my response and it just disappeared and I couldn't retrieve it.
My response basically suggested that the best approach for a curved composite deck was the FE web approach - as you seem to have adopted anyway - as this allowed explicit modelling of the bracing which, due to the interaction between transverse bending and torsion of, plays a major part in the global behaviour of the deck. However, I did warn about the size of the model, even for a single span, that this may make analysis times unworkable (especially if load optimisation and dynamics was required). My recommendation was still to use this approach but to be as economic as possible with the fineness of the mesh.
I have examined your model which you kindly attached to your second post, which is very detailed, and I cannot see anything wrong with what you have done, but the number of elements in each of the webs is quite large which seems to have made the model large enough to fail in the analysis. I have tried various tricks that I have used in the past such as renumbering the joints, adjusting the memory parameters in the "Options menu" but cannot get a solution for a single load case.
I will continue to try to find a solution, as this is quite unusual, and I have created models like this in the past and not had the same problem. This is a screenshot of a five span FE web composite deck I have created where the only real difference to your model is that I only used two elements in the depth of the web. I can appreciate that you may need a few more as your bracing is not at the level of the flanges but I believe these could be minimised to get your model to work (you can provide non uniform spacing to suit your needs).
Sorry I can’t be more help at this stage, but I will continue to investigate for a short while to see if I can find a workaround.
Kind regards
Dave Geeves
Message 4 of 11
dave_geeves
Since my last reply I have done further research by reducing the number of elements in the depth of the webs to 4 rather than 14 with relative spacing 0, 0.1, 0.5, 0.88, 1.0 so that the nodes coincided with the nodes of the bracing.  I also made adjustments to the default torsion calculation grid size for the design sections to 20 by 20 as the large numbers you had set were affecting the analysis time  quite considerably.  In addition I set the memory management parameters to 250 and 250 to ensure a reasonable size for this model.
This gave me a good solution with the three dead load cases analysing and returning all results in about 30 seconds.  I created influence surfaces for all points along virtual member 1 which took about 15 minutes with subsequent load optimisation for sagging moment using LM5 taking about 1 minute which generated about 120 load cases and 99 load combinations.  It took 12 minutes to solve all these load cases and return the results, which on an initial inspection looked as how I would expect them to.
I hope this has helped to get your analysis solved and if it has please mark my reply as a solution so that others may benefit.  Thanks
Kind regards
Dave Geeves
Message 5 of 11
Dear Dave,
Thank you for your prompt reply.
Now the model works well.
I have another problem.
It seems like the dynamic analyses do not perform. One of the error messages is the "incrementation of database" memory and another is the " elastic module do not given"
I go to the Section Properties and select the Advanced Beam Properties/ modify elastic and shear modulus and I give the steel properties to the braces.
I read that for the design beam the transformed parameters are calculated automatically, anyway I did the same for Fe elements.
The analyses do not perform yet.
 I will appreciate it if you could check my model and give me some advice.
Thank you
Message 6 of 11
dave_geeves
HI,
Sorry for the delay on this.  I have tried many tricks to try to get the dynamics to work for this model but without luck.  It is not just the size of the problem but the minimum bandwidth of the stiffness matrix due to the cross bracing joining nodes that are quite removed from each other within the matrix.  The only thing I can suggest at the moment is to cut the number of elements in the longitudinal direction to reduce the problem size again.  If I come up with any other solution I will get back to you.
Sorry I haven't been able to solve this one.
Kind regards
Dave Geeves
Message 7 of 11
dave_geeves
Good news, I think I may have a solution to your problem in solving the normal modes analysis for your curved composite deck.
Following my previous thoughts that the matrix bandwidth was the problem I decided to renumber all the joints and elements in the model so that there was a general progression along the span.  This isn't going to reduce the final bandwidth of the problem, as the program tries to optimize the starting bandwidth, based upon the node and element numbering by internally renumbering.  I believe the root of our problem is that the starting bandwidth was so large that the memory required to optimise it was too much.  Hence, by optimising a starting point the memory required would be less.
So to summarise I first of all renumbered the joint using the joint details form by sorting the joints first by "longitudinal beam" then by X coordinate, then by Y coordinate and finally by Z coordinate.  I then renumbered the joints from 1 in the sorted order.
I did the same in the member details form by sorting the elements using the first node reference and then renumbering this sorted order from 1.
Finally I set the memory parameters from the options menu and I was able to get a solution for ten mode shapes.
From this I did notice that the vertical positions of the joint in the web of one of the girders was not the same as the others and the diagonal bracing was not connecting to this web.  So these will need correcting before the renumbering takes place.
You will also notice that the steel webs are very flexible as they have no stiffeners modelled and many of the modes generated are just vibrations of the webs or other flexible components.  I think web stiffeners should stiffen up the response.
I hope this helps.  Please mark this post as a solution if it has helped solve your problem so that others may benefit.  Thanks
Kind regards
Dave Geeves
Message 8 of 11
Dear Gave,
Thank you for your support, I appreciate it.
I follow all your steps and the dynamic analysis now works.
I also put the transverse web stiffeners but I realize that the period/frequency doesn't change and the steel webs still seem very flexible in the deflected mode. This makes me wonder if I put the web stiffeners correctly in the model.
Could you have a look at the model now?
Thank you Dave
Message 9 of 11
dave_geeves
The web stiffeners define in the design beams do not automatically get created in the analysis model and are used for web design checks in the actual beam design.  You will need to manually create the vertical web stiffeners and assign appropriate section properties within the structural model.
I manually added vertical members at each location in the "Bottom Bracing" sub model as shown  (I did this by creating a single beam going from top flange to bottom flange and then using the "Split members" facility in the sub model members form and selecting to split at crossing nodes to form the four vertical members at each location.  I created a new section made up from four of the angles you previously used and assigned this to the new members.
The dynamic solution still worked so there was no need to renumber as before.  The mode shapes created  now seemed a lot more as I would expect, with the main bending mode at about 4 hertz and the second bending mode at about 10 hertz (shown here) with a lot of the local modes of the flexible webs now not existing in the first 10 modes
I hope this helps.
Kind regards
Dave Geeves
Message 10 of 11
Dear Dave,
Thank you very much!
Could you please share with me the model you modify where you added the stiffeners?
Kind regards,
Arlinda
Message 11 of 11
dave_geeves
I attach my zipped up model file but you may need the latest version of ASBD (20.2.140) as I created it in this version and I think your file was created using 20.0.0  and it may not be forward compatible.  Try it anyway.  You can easily upgrade to the latest version if necessary by applying the appropriate patch from the Autodesk desktop manager (if you are running it).
Good luck and kind regards
Dave Geeves
