ASBD 2018 crack width check issue
I am getting different crack width from ASBD 2017 and ASBD 2018.
It seems that ASBD crack width calculations are not right.
While calculating strain in the section, ASBD 2018 mistakenly takes effective fctm in negative which ultimately results in higher strain and higher crack width.
Regards
Nihit Sharma
karoly_tarcsi
Hi Nihit,
We fixed the tensile strength (fctm) signage issue in ASBD 2019, so crack width calculation in the current version is similar to what it was in the 2017 version.
Karoly Tarcsi
Software Development
(If you are satisfied with the answer, can you mark the issue as "resolved", so others can learn from it. Thanks.)
Karoly Tarcsi
karoly_tarcsi
Hi Nihit,
Just a follow up.. Are you satisfied with the crack width calcs in ASBD 2019.x?
Karoly Tarcsi
(If you are satisfied with the answer, can you "Accept Solution ", so others can learn from it. Thanks.)
Karoly Tarcsi
