Hi there,
I would like to check if I'm correctly applying secondary temperature and shrinkage effects to my bridge model.
The bridge is simply supported super t girder with two identical spans (28m each) and a 35 degree skew. As I understand the skew of the bridge creates secondary thermal and shrinkage effects which need to be applied to the beam module.
I've taken the moments from the differential temperature analysis and calculated shrinkage stresses (see attached images) and applied them as a "Temperature Primary Moment" to the longitudinal beams in the bridge model (see attached).
So is this the right way to do it because there isn't any option to apply the secondary shrinkage effects to the bridge model?
There is however an option in the transfer mapped results for shrinkage & creep to transfer to a design beam.
Your help would be greatly appreciated.
Patrick Kwiecinski
