Stingray Forum (Read Only)
Welcome to Autodesk’s Stingray Forums. Share your knowledge, ask questions, and explore popular Stingray topics.
Stingray install error
15 REPLIES 15
Message 1 of 16
G.LeeJ
661 Views, 15 Replies
I'm getting an error trying to install Stingray, and has to do with not being able to load adlmpit.dll (127) ! , in user's appdata dir.
Oddly, in my  user/user DIr, there is NO appdata dir.
 I ran this as admin.
As noted LY and ue4 installed perfectly fine so I"ve no idea whats going on here.
TY to anyone that can get me past this.
IE: Can I safely ignore these errors and keep installing ?
TY so much
lee
15 REPLIES 15
Message 2 of 16
3dMastermind
in reply to: G.LeeJ
The "AppData" data folder is most likely there.
It's usually a hidden folder.
If not, create it:
C:\Users\YourUserName\AppData
and try again.
I spoke to our build engineer who indicated that he is not aware that we store anything there at this location during install.
Let us know.
Manny Papamanos
StingRay | MotionBuilder | Maya | Mudbox
Games QA Specialist
Message 3 of 16
G.LeeJ
in reply to: 3dMastermind
You're right its very hidden, which is odd as normally its not for me anyway.
I rebooted today, redownloaded just in case, and still getting this here in Windows 10 pro 64 bit English:
Error
Failed to load c:\users\neigh\appdata\local\temp\_ai76bd.tmp\setup\adlmpit.dll (127)!
OK
THen this one:
Error
adlmPITValidateKey was not found in C:\Users\neigh\AppData\Local\Temp\_AI76BD.tmp\Setup\adlmPIT.dll!
OK
Oddly enough here again, after those 2 errors, it still continues to install as if nothing were wrong,- but I doubt it is so I"m cancelling install until I hear more.
Thx for any ideas on this.
lee
Message 4 of 16
joshua.racz
in reply to: G.LeeJ
Hello Lee,
Which version of Stingray are you trying to install?  I should be able to isolate it better knowing that.
Thanks!
Joshua
Joshua Racz
Sr. Software Engineer
Message 5 of 16
G.LeeJ
in reply to: joshua.racz
I responded vi email but here is also fine. I tried to install the very latest,-about 4 or 5 days ago. I doubt a new one was released in that short time so that should suffice.
ty!
Message 6 of 16
joshua.racz
in reply to: G.LeeJ
We actually have released a new version of Stingray yesterday afternoon.  Can you please try it out and see if it works for you?
Stingray 1.7.1177.0
Thanks!
Joshua Racz
Message 7 of 16
G.LeeJ
Ok that worked,,ty so much 😉
lee
Sent from Mail for Windows 10
Message 8 of 16
G.LeeJ
in reply to: G.LeeJ
I have no idea whats going on,but getting these errors again.
I say 'ok' each time, and the install keeps going, but I"d rather know why its doing it, and will it affect the install in any way ?
thx
Message 9 of 16
joshua.racz
in reply to: G.LeeJ
That is interesting.  However, this shouldn't affect the installation in any way and you should still be able to Launch Stingray.
There is an application called DependencyWalker, it opens DLLs to see if there are any issues with it, whether it being corrupted, missing dependencies, etc.  Could you open it and point it to <Installer Directory>\Setup\adlmPIT.dll ?  It may give a clearer reasoning as to why this is happening.
Thanks!
Joshua Racz
Message 10 of 16
G.LeeJ
Doesn't officially support windows 10, but I ran based on windows 10 compat settings,and got this:
Error: At least one required implicit or forwarded dependency was not found.
Error: At least one module has an unresolved import due to a missing export function in an implicitly dependent module.
Error: Modules with different CPU types were found.
Error: A circular dependency was detected.
Warning: At least one delay-load dependency module was not found.
Warning: At least one module has an unresolved import due to a missing export function in a delay-load dependent module.
thx
Message 11 of 16
joshua.racz
in reply to: G.LeeJ
Could you provide a screenshot of the main window?  The errors provided sounds like something is missing but I cannot really tell from the error message alone.
Thanks!
Joshua Racz
Message 12 of 16
G.LeeJ
Message 13 of 16
joshua.racz
in reply to: G.LeeJ
Could you send me the install logs?  It doesn't appear that there is an issue with the dll itself.  The logs are located here:
C:\Users\<uerName>\AppData\Local\Temp\Stingray<versionNumber>Install.log
Thanks!
Joshua Racz
Message 14 of 16
G.LeeJ
Here you go and thx for looking into this.
stingray log
Message 15 of 16
joshua.racz
in reply to: G.LeeJ
Hello Lee,
I noticed you are using a web installer for installation.  I cannot seem to replicate this on my end, but it is possible the network isn't downloading all the necessary files due to possible connection issues/drops/etc.  There is another download available for those with possible connection issues on the trial page:
http://www.autodesk.com/products/stingray/free-trial
Could you try using the Download Manager version?
Thanks!
Joshua Racz
Message 16 of 16
G.LeeJ
Ok that stopped the errors, ty ! 😉
lee
