Whenever I try to run my project, I get an error message saying that stingray can't find a specified file.
I can run it with "Test Level" just fine though.
I have no idea how to fix this.
Screenshot of the error:
https://gyazo.com/e8e7829e2504c98d0cb83c208027a265
Solved by _robbs_. Go to Solution.
Is this a project for which you've modified the LUA files locally? If so, setting a breakpoint near the error and tracing through the code in the debugger may help.
The template projects that ship with Stingray should run without error.
Are you using 1.7?
You may need to add your Lua script to your boot.package.
By default, the boot.package loads all lua scripts that are found under `script/lua/*`, but I notice yours is set to `script/move/`.
You can just change the boot.package file to use:
lua = [ "core/appkit/lua/*" "core/humanik/lua/*" "core/wwise/lua/*" "core/scaleform_studio/lua/*" "script/lua/*" "script/move/*" ]
or
lua = [ "core/appkit/lua/*" "core/humanik/lua/*" "core/wwise/lua/*" "core/scaleform_studio/lua/*" "script/*" ]
You can read more about packages and what they're for under this section of the help
cheers
@_robbs_ wrote:Are you using 1.7?
lua = [ "core/appkit/lua/*" "core/humanik/lua/*" "core/wwise/lua/*" "core/scaleform_studio/lua/*" "script/lua/*" "script/move/*" ]or
lua = [ "core/appkit/lua/*" "core/humanik/lua/*" "core/wwise/lua/*" "core/scaleform_studio/lua/*" "script/*" ]You can read more about packages and what they're for under this section of the help
cheers
I see, I'll try that tomorrow. I'll let you know if it worked or not by then.
