Stingray Forum (Read Only)
Welcome to Autodesk’s Stingray Forums. Share your knowledge, ask questions, and explore popular Stingray topics.
Stingray can't find files while trying to run my project.
4 REPLIES 4
360 Views, 4 Replies
Whenever I try to run my project, I get an error message saying that stingray can't find a specified file.
I can run it with "Test Level" just fine though.
I have no idea how to fix this.
Screenshot of the error:
https://gyazo.com/e8e7829e2504c98d0cb83c208027a265
4 REPLIES 4
__ben__
Is this a project for which you've modified the LUA files locally? If so, setting a breakpoint near the error and tracing through the code in the debugger may help.
The template projects that ship with Stingray should run without error.
_robbs_
Are you using 1.7?
You may need to add your Lua script to your boot.package.
By default, the boot.package loads all lua scripts that are found under `script/lua/*`, but I notice yours is set to `script/move/`.
You can just change the boot.package file to use:
lua = [
	"core/appkit/lua/*"
	"core/humanik/lua/*"
	"core/wwise/lua/*"
	"core/scaleform_studio/lua/*"
	"script/lua/*"
        "script/move/*"
or
lua = [
	"core/appkit/lua/*"
	"core/wwise/lua/*"
	"script/*"
You can read more about packages and what  they're for under this section of the help
http://help.autodesk.com/view/Stingray/ENU/?guid=__stingray_help_managing_content_loading_unloading_...
cheers
in reply to: _robbs_
@_robbs_ wrote:
Are you using 1.7?
lua = [
	"core/appkit/lua/*"
	"core/wwise/lua/*"
	"script/lua/*"
        "script/move/*"
or
lua = [
	"core/appkit/lua/*"
	"core/wwise/lua/*"
	"script/*"
cheers
I see, I'll try that tomorrow. I'll let you know if it worked or not by then.
This worked, thanks alot!
